It is currently Sat Jun 13, 2026 11:38 pm
PostPosted: Wed Dec 24, 2003 6:22 pm
I have an 88 dodge dakota with 205000 miles on it. The motor runs great, and it shifts 1, 2, and 3 just fine, but the electronic overdrive is intermittent. It makes no difference whether I push the o/d button on or off.
Any ideas?
PostPosted: Thu Dec 25, 2003 8:24 am
Had a freind with an explorer that had the same problem, ended up being some sort of switch.
PostPosted: Thu Dec 25, 2003 2:56 pm
check the wires for the O/D switch. See if any shorts are present.
PostPosted: Mon Dec 29, 2003 9:22 pm
no shorts, but I am thinking about replacing the overdrive button itself.
Just trying to see if the truck is worth keeping. I'm only getting 15 mpg right now.
PostPosted: Tue Dec 30, 2003 9:25 am
Look on top of your tranny. Of corse under the truck...anyways...there is a small diode or relay switch there . they do go bad. It should be a green looking thing about the size of a matchbox. Hope that helps....good luck
PostPosted: Tue Dec 30, 2003 11:09 pm
before u replace n e thing make sure u have power to the switch. if u have a multi meter or can use one make sure there is continuity in the wires as well cause it might not be the switch. hope this can help. n e questions just ask if i don't know somebody will. matt. i am a technician so i might be able to help on some stuff.
PostPosted: Thu Jan 01, 2004 10:01 pm
If I push the button to turn the o/d "off" the light comes on... so I guess it has power coming to it. All the fuses are good too.
I'm gonna check out that thing on top of the tranny though... Thanks.
