It is currently Tue Jun 23, 2026 7:31 pm
 Post subject: SBC cam specs needed
PostPosted: Mon Dec 02, 2013 5:59 pm
Hi,,,
I got a SBC cam and I lost the cam card. I've looked around the internet and I just cant find out anything. If I remember correctly, it was a Crane cam. What throws me off is the cam came with Lunati flat tappet hyd lifters. I got the parts from a guy that was out to build a 383 but bailed out from the project and found a running 350. I bought a big box of new parts from him. so now im kinda lost with the cam. the numbers stamped on the cam are 115835 and 252323. for all I know, I may have a bunch of mix-matched parts. This may be why he bailed out of the project.
Im hoping that someone that's savy about cam tech can help me out.
Thanks.
 Post subject: Re: SBC cam specs needed
PostPosted: Mon Dec 02, 2013 6:04 pm
Most lifters are made by the same manufacturer. And most cams are made for Lunati, Crane, etc. by the parent company for Bullet. Good luck with the numbers...
PostPosted: Mon Dec 02, 2013 6:48 pm
I took a rag to the front of the cam and scrubbed the protective film off of it and found out that its a Lunati cam the numbers I found are 31805 109. I'm gonna run those numbers.
PostPosted: Mon Dec 02, 2013 8:48 pm
The 31805 number relates to the Olds 330-455 motors. But this particular cam has the fuel pump eccentric on the cam like a SBC. 330-455 motors run a bolt on eccentric on the timing chain gear.
PostPosted: Mon Dec 02, 2013 9:41 pm
Don't think those numbers posted are the ones you need. Try the other end. If not, call them...
