It is currently Tue Jun 23, 2026 7:38 pm
 Post subject: g80 rear ends
PostPosted: Wed Jan 04, 2012 9:42 pm
so i was at the junk yard today picking up a few more odds and ends and seen a 1995 buick roadmaster... and of course against my better judgement i just happend to pop open the glove box amd noticed that it had a code listing for a g80.... an lsd in a station wagon...
so i got to looking some more and found this information
Buick road master sedan:
2GC / 2.56 (GM8)/ 11" / 1566mm
2GQ / same as 2GC w/LS
2NS / 2.93 (GW9)/ 11" / 1566mm w/LS
LS = Limited Slip
2YN 2.56 (GM8) not available with G80 / ls
2YF /2.93 (GW9) - housing code - open diff
2YG / 2.93 (GW9) with G80 /ls
would a 2.56 or a 2.93 be to low of a ratio for the stock 80hp? i mean cruising speed on the freeway would be right around 1800-2200rpm
Friends don't let friends drive stock...
76 mikado, emissions delete, dual alternator, rejetted 1.9 carb swap, non factory body lines
soon non points distributor, single (semi sealed beam) head light conversion
 Post subject: Re: g80 rear ends
PostPosted: Thu Jan 05, 2012 12:25 am
Australian LUV Guru
Are you saying the Buick pumpkin will drop straight in, or will you use the whole rear.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Thu Jan 05, 2012 5:51 am
These are pretty good axles . Make sure you get the Auburn style clutch type posi . G80 is GM s code for limited slip for all models across the model line that will include the Eaton Gov-loc from the trucks which is less than desirable , but plenty strong for a stock Luv motor . These are 30 spline with 8.5 inch ring gears with C-clip retention . I just pulled the posi unit out of a wrecked caprice with 56,000 miles and put it in my 91 C1500
PostPosted: Sat Feb 18, 2012 2:29 am
sorry to hijack this... but... other than the truck version which cars had posi? i have heads the gov-loc has issues under power and doesnt lock except for at certain speeds and conditions... would really like a lsd to go with the 4.3 with all the rain here any traction i can get would be a help
