It is currently Sun Feb 01, 2026 2:25 am
 Post subject: trouble shooting ideas
PostPosted: Mon Nov 15, 2010 7:20 pm
Ok so I'm close to having mt 1980 4x4 chevy luv running I'm sure of it but here is the problem I'm having.. The truck runs great when its just running off the battery but when I hook up the wire on the positive terminal to the lights and alternator it back fires , runs slow, and I can't shift out of 1 . I've replaced the voltage regulator, all the battery terminal cables I'm fresh out of ideas please point me in the right direction.
PostPosted: Mon Nov 15, 2010 8:18 pm
Sounds like you may have a bad alternator. To find out, loosen the neg. battery cable, then start up the truck. With the truck running, walk over to the battery and (with all accessories and lights off) pull off the negative battery cable. If the engine dies, your alternator is bad. If not, its something else.
Hope this helps! :ebiggrin
My Rides:
2002 Mazda B4000 4x4
1978 Chevy LUV - Sold :(
1990 Kawasaki EX500
2008 Yamaha TTR230
PostPosted: Mon Nov 15, 2010 10:04 pm
Ok ill give it a shot thanks, I would love it if a part was the only problem.
PostPosted: Tue Nov 16, 2010 12:44 pm
Sadly the alternator is running fine. Darn it .
PostPosted: Tue Nov 16, 2010 3:39 pm
Start at the alternator with the heavy wire and follow it to the fuse box and battery. It should always be hot. If not, you have a bad connection somewhere.
PostPosted: Fri Nov 19, 2010 10:52 pm
Ok so here are some pictures of my truck and problems it has due to wiring not connected and i cant find where they go . Is this normal
wiring or is this second hand ?
