It is currently Sun Feb 01, 2026 10:24 am
 Post subject: Air Conditioning?
PostPosted: Thu Nov 22, 2007 12:32 pm
Considering buying a LUV but after speaking to the owner i found out it has no A/C. :( Not sure if i want to purchase anymore. Anyone have any info on installing an A/C system. About how much in parts would this cost? Aftermarket systems?
PostPosted: Wed Dec 12, 2007 7:30 pm
You can do a google search for A/C parts and see how much parts would cost you. Then a good manual would probably help you see how much work is involved, also whether or not the A/C trucks had extra vents for the A/C or if it used the same ones as the heater. It probably wouln't be too much work, and I think you could probably get all the parts you would need for a couple hundred dollars. There are also aftermarket units that are universal. I'm not sure on prices, again search for them. Check JC Whitney, they usually have a lot of the universal parts like that. But in my opinion, if the truck is in good shape, I'd get it anyways. A friend of mine had an A/C truck and it seemed like we always rolled the window down or opened the vents because the drain on power wasn't worth the semi-cold air that the A/C blew anyways.
Good luck
No LUV anymore, but still in the GM truck family. Running a lifted 2002 Silverado Z-71!
